Performance and portability come together in the ThinkPad L560. A great choice for on-the-go professionals. The thin and light L560's features include long battery life, robust connectivity, optimized performance, and business-class manageability and security features.
Product Description | Lenovo ThinkPad L560 - 15.6" - Intel Core i5 - 6200U - 4 GB RAM - 500 GB HDD - UK | Product Type | Notebook | Operating System | Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence | Processor | Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache | Memory | 4 GB DDR3L (1 x 4 GB) | Storage | 500 GB HDD / 7200 rpm | Optical Drive | DVD-Writer | Display | 15.6" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics 520 | Input Device | TrackPoint, UltraNav | Keyboard | UK | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet | Battery | 6-cell - up to 11.2 hours | Dockable | Yes | Security | Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader | Dimensions (WxDxH) | 37.7 cm x 25.5 cm x 3.085 cm | Weight | 2.38 kg | Localisation | Language: English / region: United Kingdom | Manufacturer Selling Program | TopSeller | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | Limited warranty - 1 year - pick-up and return |
General | |
Operating System | Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence |
Processor / Chipset | |
CPU | Intel Core i5 (6th Gen) 6200U / 2.3 GHz |
Max Turbo Speed | 2.8 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 16 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz / PC3L-12800 |
Rated Speed | 1600 MHz |
Form Factor | SO-DIMM 204-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 500 GB HDD SATA 6Gb/s / 7200 rpm |
Optical Drive | DVD-Writer - tray |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 220 cd/m² |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 520 |
Camera | Yes - 720p |
Sound | Stereo speakers, two microphones |
Codec | Realtek ALC3245 |
Compliant Standards | High Definition Audio |
Input | |
Type | Keyboard, TrackPoint, UltraNav |
Keyboard Layout | UK |
Features | Spill-resistant, multi-touch touchpad, buttonless touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | Intel Dual Band Wireless-AC 8260 - M.2 Card |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-V |
Wireless Broadband (WWAN) | |
Generation | WWAN upgradable |
Battery | |
Technology | 6-cell Lithium Ion |
Capacity | 48 Wh |
Run Time | Up to 11.2 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt |
Connections & Expansion | |
Slots | 1 x ExpressCard/34 (1 free) |
Interfaces Details | 4 x USB 3.0 , VGA , Mini DisplayPort , LAN , Dock , Headphone/microphone combo jack |
Memory Card Reader | 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card) |
Software | |
Software Included | ThinkVantage Rescue and Recovery, Adobe Reader, ThinkVantage System Update, ThinkVantage Product Recovery, Lenovo Solution Center, McAfee LiveSafe (30 days trial) |
Miscellaneous | |
Case Material | Polycarbonate ABS |
Dockable | Yes |
Features | Administrator password, hard drive password, power-on password, ThinkVantage Active Protection System, 1 USB 3.0 (Always On), ThinkEngine, MIL-STD-810G tested |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | RoHS, GREENGUARD |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 2.38 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - pick-up and return |
