With memory, you can run multiple high-end software applications without stalling your PC. Visuals look great on the ThinkPad L460, thanks to integrated Intel HD graphics. Whether you're creating presentations, writing reports, or kicking back with a movie, the L460 fits the bill.
At just 0.96" thin and weighing in at as little as 1.9 kg, the L460 is a great choice for on-the-go professionals. But, the L460 is also durable. It meets 12 US military-spec tests for ruggedness, durability, and quality. In addition, innovative roll-cage technology and glass-fiber reinforced plastic add extra strength and rigidity.
Product Description | Lenovo ThinkPad L460 - 14" - Intel Core i5 - 6200U - 4 GB RAM - 192 GB SSD - UK | Product Type | Notebook | Operating System | Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence | Processor | Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache | Memory | 4 GB DDR3L (1 x 4 GB) | Storage | 192 GB SSD | Display | 14" LED backlight 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 520 | Input Device | TrackPoint, UltraNav | Keyboard | UK | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet | Battery | 6-cell - up to 12.7 hours | Dockable | Yes | Security | Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader | Colour | Black | Dimensions (WxDxH) | 33.9 cm x 23.5 cm x 2.43 cm | Weight | 2.02 kg | Localisation | Language: English / region: United Kingdom | Manufacturer Selling Program | TopSeller | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | Limited warranty - 1 year - pick-up and return |
General | |
Operating System | Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence |
Processor / Chipset | |
CPU | Intel Core i5 (6th Gen) 6200U / 2.3 GHz |
Max Turbo Speed | 2.8 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 32 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz / PC3L-12800 |
Rated Speed | 1600 MHz |
Form Factor | SO-DIMM 204-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 192 GB SSD SATA 6Gb/s |
Display | |
Type | 14" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 250 cd/m² |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 520 |
Camera | Yes - 720p |
Sound | Stereo speakers, two microphones |
Codec | Realtek ALC3245 |
Compliant Standards | High Definition Audio |
Input | |
Type | Keyboard, TrackPoint, UltraNav |
Keyboard Layout | UK |
Features | Spill-resistant, multi-touch touchpad, buttonless touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | Intel Dual Band Wireless-AC 8260 - M.2 Card |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-V |
Wireless Broadband (WWAN) | |
Generation | WWAN upgradable |
Battery | |
Technology | 6-cell Lithium Ion |
Capacity | 48 Wh |
Run Time | Up to 12.7 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 20 V, 2.25 A |
Connections & Expansion | |
Interfaces Details | 3 x USB 3.0 , Mini DisplayPort , VGA , LAN , Headphone/microphone combo jack , Dock |
Memory Card Reader | 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card) |
Software | |
Software Included | ThinkVantage Rescue and Recovery, Adobe Reader, ThinkVantage System Update, ThinkVantage Product Recovery, Lenovo Solution Center, McAfee LiveSafe (30 days trial) |
Miscellaneous | |
Colour | Black |
Case Material | Polycarbonate ABS |
Dockable | Yes |
Features | Security lock slot (cable lock sold separately), administrator password, hard drive password, power-on password, 1 USB 3.0 (Always On), ThinkEngine, MIL-STD-810G tested |
Included Accessories | Power adapter |
Compliant Standards | RoHS, GREENGUARD |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 2.02 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - pick-up and return |
