PERFECT COMBINATION OF AFFORDABILITY, ALL-ROUND FEATURES AND SMART PERFORMANCE
Built to last and ultimately affordable, the Lenovo G580 notebooks make sure that you have all your essentials in place. It features a 2nd or 3rd generation Intel® Core™ processor. HD graphics support, stereo speakers and integrated DVD-RW drive make these notebooks good for basic multimedia. Plus, features like VeriFace™ face recognition technology provides a fun way to login to your PC
KEY SPECIFICATIONS
Product Description | Lenovo G580 - 15.6" - Intel Celeron B830 - 3 GB RAM - 320 GB HDD - QWERTY UK | Product Type | Notebook | Operating System | Win 8 | Processor | Intel Celeron B830 / 1.8 GHz / 2 MB Cache | Memory | 3 GB DDR3 (1 x 4 GB) | Storage | 320 GB HDD / 5400 rpm | Optical Drive | DVD SuperMulti | Display | 15.6" LED backlight VibrantView 1366 x 768 / HD | Graphics | Intel HD Graphics | Keyboard | QWERTY UK | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11b/g/n, Bluetooth 4.0, 10/100 Ethernet | Battery | 6-cell - up to 6 hours | Colour | Glossy blue | Dimensions (WxDxH) | 37.6 cm x 24.5 cm x 3.43 cm | Weight | 2.6 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 1 year |
General | |
Operating System | Windows 8 |
Processor / Chipset | |
CPU | Intel Celeron B830 / 1.8 GHz |
Number of Cores | Dual-Core |
Cache | 2 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel HM76 Express |
Features | Integrated memory controller |
Memory | |
RAM | 3 GB (1 x 4 GB) |
Max RAM Supported | 8 GB |
Technology | DDR3 SDRAM |
Speed | 1333 MHz / PC3-12800 |
Rated Speed | 1600 MHz |
Form Factor | SO-DIMM 204-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 320 GB HDD SATA 3Gb/s / 5400 rpm |
Optical Drive | DVD±RW (±R DL) / DVD-RAM fixed - tray |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | VibrantView, glossy |
Audio & Video | |
Graphics Processor | Intel HD Graphics |
Camera | Yes |
Video Resolutions | 1280 x 720 |
Sound | Stereo speakers, microphone |
Codec | Realtek ALC269Q |
Compliant Standards | High Definition Audio, Dolby Advanced Audio v2 |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | QWERTY UK |
Features | Multi-touch touchpad |
Communications | |
Wireless | 802.11b/g/n, Bluetooth 4.0 |
Network Interface | 10/100 Ethernet |
Ethernet Controller | Atheros AR8162 |
Battery | |
Technology | 6-cell Lithium Ion |
Installed Qty | 1 |
Capacity | 48 Wh |
Run Time | Up to 6 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt |
Connections & Expansion | |
Interfaces | 2 x USB 3.0 , USB 2.0 , Headphone/microphone combo jack , HDMI , LAN , VGA |
Memory Card Reader | 2 in 1 (SD Card, MultiMediaCard) |
Software | |
Software Included | Microsoft Office 2010 Transition Kit |
Miscellaneous | |
Case Material | Polycarbonate ABS |
Features | Security lock slot (cable lock sold separately), administrator password, hard drive password |
Included Accessories | Power adapter |
Compliant Standards | RoHS |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 2.6 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
