Whether you want a laptop for a small business or a home office, Lenovo B series laptops will increase your productivity.
Product Description | Lenovo B50-45 - 15.6" - A6 6310 - 4 GB RAM - 500 GB HDD | Product Type | Notebook | Operating System | Windows 10 Home | Processor | AMD A6 6310 / 1.8 GHz / 2 MB Cache | Memory | 4 GB DDR3L (1 x 4 GB) | Storage | 500 GB HDD / 5400 rpm | Optical Drive | DVD-Writer | Display | 15.6" LED backlight 1366 x 768 / HD | Graphics | AMD Radeon R4 | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet | Battery | 4-cell | Dimensions (WxDxH) | 38 cm x 26.2 cm x 2.47 cm | Weight | 2.32 kg | Localisation | Language: English / region: United Kingdom |
General | |
Processor / Chipset | |
CPU | AMD A6 6310 / 1.8 GHz |
Number of Cores | Quad-Core |
Cache | L2 - 2 MB |
64-bit Computing | Yes |
Features | Integrated memory controller |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 16 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz / PC3L-12800 |
Rated Speed | 1600 MHz |
Form Factor | SO-DIMM 204-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 500 GB HDD SATA 6Gb/s / 5400 rpm |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | AMD Radeon R4 |
Camera | Yes |
Sound | Stereo speakers, microphone |
Compliant Standards | High Definition Audio |
Input | |
Type | Keyboard, touchpad |
Communications | |
Wireless | 802.11b/g/n, Bluetooth 4.0 |
Wireless Controller | M.2 Card |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 4-cell Lithium Ion |
Capacity | 32 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt, 20 V, 3.25 A |
Connections & Expansion | |
Interfaces | 2 x USB 3.0 , USB 2.0 , VGA , HDMI , LAN , Headphone/microphone combo jack |
Memory Card Reader | 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card) |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), administrator password, hard drive password, power-on password |
Included Accessories | Power adapter |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 2.32 kg |
