ITEM | QTY | PRICE |
HP ProBook 440 G9 Intel Core i5-1235U...
3 | £2,099.34 |
Philips B-Line 243B1 24" 1920x10...
4 | £970.08 |
Satechi Slim X1 Bluetooth Keyboard-UK
3 | £179.94 |
The LaCie d2 Professional performs perfectly on Macs and PCs alike and features superior performance and reliability.
Product Description | LaCie d2 Professional STHA8000800 - hard drive - 8 TB - USB 3.1 Gen 2 | Type | Hard drive - external (desktop) | Capacity | 8 TB | Interface | USB 3.1 Gen 2 - USB-C | Features | Security lock slot (cable lock sold separately), vibration dampening, LED status indicator, Enterprise | Power Source | Included AC adapter | Dimensions (WxDxH) | 130 mm x 60 mm x 188.5 mm | Weight | 1.4 kg | Localisation | Worldwide | Manufacturer Warranty | 5-year warranty | Bundled with | Seagate Rescue Data Recovery |
General | |
Device Type | Hard drive - external (desktop) |
Capacity | 8 TB |
Interface | USB 3.1 Gen 2 |
Width | 130 mm |
Depth | 60 mm |
Height | 188.5 mm |
Weight | 1.4 kg |
Performance | |
Max Data Transfer Rate | 240 MB/s |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.1 Gen 2 - 24 pin USB-C |
Power | |
Power Device | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Software & System Requirements | |
Software Included | Adobe Creative Cloud (30 days trial) |
OS Required | Apple macOS Sierra 10.12 or later, Windows 10 or later |
Miscellaneous | |
Dimensions & Weight (Shipping) | |
Shipping Width | 18 cm |
Shipping Depth | 24 cm |
Shipping Height | 12 cm |
Shipping Weight | 1.6 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Customer return - item has been opened but is in excellent condition
Ref: F47C 048579 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
£192.19
