Get the job done faster - on any computer - with dual Thunderbolt 2 and USB 3.0. Thanks to its innovative, all-aluminum unibody design, you'll notice incredibly low vibration and operating noise.
Product Description | LaCie d2 Thunderbolt 2 - hard drive - 6 TB - USB 3.0 / Thunderbolt 2 | Type | Hard drive - external (desktop) | Capacity | 6 TB | Interface | USB 3.0 / Thunderbolt 2 | Data Transfer Rate | 20 Gbps (Thunderbolt 2) / 5.0 Gbps (USB 3.0) | Spindle Speed | 7200 rpm | Power Source | Included AC adapter | Dimensions (WxDxH) | 217 mm x 130 mm x 60 mm | Weight | 1.7 kg | Localisation | Worldwide | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Hard drive - external (desktop) |
Capacity | 6 TB |
Width | 217 mm |
Depth | 130 mm |
Height | 60 mm |
Weight | 1.7 kg |
Performance | |
Interface Transfer Rate | 20 Gbps (Thunderbolt 2) / 5.0 Gbps (USB 3.0) |
Max Data Transfer Rate | 180 MB/s |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.0 , 2 x Thunderbolt 2 |
Power | |
Power Device | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Software & System Requirements | |
OS Required | Microsoft Windows 7 / Windows 8, Apple OS X 10.8.5 Mountain Lion or later |
Miscellaneous | |
Cables Included | 1 x Thunderbolt cable , 1 x USB 3.0 cable |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
