ITEM | QTY | PRICE |
StarTech.com 1 Port RS232 Serial to I...
1 | £148.28 |
Samsung 2TB 980 PRO PCIe M.2 SSD
4 | £850.88 |
The essential addition to SSD-based laptops and all-in-one computers with limited storage capacity, the latest d2 USB-C desktop drive massively expands capacity to up to 10TB for professional bandwidth intensive creative applications. The LaCie d2 Professional performs perfectly on Macs and PCs alike and also features Seagate BarraCuda Pro enterprise-class hard drives for industry-leading performance and reliability.
Product Description | LaCie d2 Professional STHA4000800 - hard drive - 4 TB - USB 3.1 | Type | Hard drive - external (desktop) | Capacity | 4 TB | Interface | USB 3.1 - USB-C | Features | Security lock slot (cable lock sold separately), vibration dampening, LED status indicator, Enterprise | Power Source | Included AC adapter | Dimensions (WxDxH) | 130 mm x 60 mm x 188.5 mm | Weight | 1.4 kg | Localisation | Worldwide | Manufacturer Warranty | 5-year warranty | Bundled with | Seagate Rescue Data Recovery |
General | |
Device Type | Hard drive - external (desktop) |
Capacity | 4 TB |
Interface | USB 3.1 |
Width | 130 mm |
Depth | 60 mm |
Height | 188.5 mm |
Weight | 1.4 kg |
Performance | |
Max Data Transfer Rate | 240 MB/s |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.1 |
Power | |
Power Device | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Software & System Requirements | |
Software Included | Adobe Creative Cloud (30 days trial) |
OS Required | Apple macOS Sierra 10.12 or later, Windows 10 or later |
Miscellaneous | |
Enclosure Material | Aluminium |
Dimensions & Weight (Shipping) | |
Shipping Width | 18 cm |
Shipping Depth | 24 cm |
Shipping Height | 12 cm |
Shipping Weight | 1.6 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
