The wireless and network Kodak i1190WN Scanner makes life a lot easier and more efficient for any business. It is perfect for sharing and work collaborations. You can easily integrate it with your existing business applications and create custom integrations. And you can even manage security levels and settings. Welcome to a new world of flexible, versatile, powerful, convenient and stress-free scanning. Don't let your business miss out on the power of wireless network scanners.
Product Description | Kodak i1190WN - document scanner - desktop - USB 2.0, LAN, Wi-Fi(n) |
Device Type | Document scanner - desktop |
Interface Type | USB 2.0, LAN, Wi-Fi(n) |
Scanning Sensor Type | CMOS / CIS |
Light Source | Dual LED |
Additional Functions | Scan to print, scan to network share, scan to cloud, scan to smart devices, scan to FTP, scan to file, scan to folder |
Max Supported Document Size | 215 x 355.6 mm |
Input Type | Colour |
Optical Resolution | 600 dpi x 600 dpi |
Max Document Scan Speed | 40 ppm (mono) / 40 ppm (colour) |
Max Document Size | 215 mm x 355.6 mm |
Automatic Duplexing | Yes |
Supported Document Type | Plain paper, business card, embossed card |
Document Feeder Type | Automatic |
Document Storage Capacity | 75 sheets |
Duty Cycle | 5000 scans per day |
Power | AC 120/230 V (50/60 Hz) |
System Requirements | Microsoft Windows Server 2008 x64 Edition, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 (32/64 bits) |
Dimensions (WxDxH) | 33 cm x 16.2 cm x 24.6 cm |
Weight | 3.2 kg |
Environmental Standards | ENERGY STAR Qualified |
General | |
Scanner | |
Bulb / Light Source Type | Dual LED |
Max Document Scan Speed B/W | 40 ppm |
Max Document Scan Speed Colour | 40 ppm |
Barcodes | UPC-A, UPC-E, Codabar, Code 128, Code 3 of 9, Interleaved 2 of 5, PDF417, EAN-8, EAN-13 |
Scanner Speed Details | 40 ppm - 300 dpi , 80 ipm - duplex |
Scanner Features | Intelligent Document Protection |
Scan File Formats | BMP, JPEG, PNG, TIFF |
Compliant Standards | TWAIN, ISIS |
Media Handling | |
Expansion / Connectivity | |
Interfaces Details | USB 2.0 , LAN |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational (Standby) | 21 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Software / System Requirements | |
OS Required | Microsoft Windows Server 2008 x64 Edition, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 (32/64 bits) |
Dimensions & Weight | |
Width | 33 cm |
Depth | 16.2 cm |
Height | 24.6 cm |
Weight | 3.2 kg |
Environmental Parameters | |
Min Operating Temperature | 15 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 15 - 80% |
Sound Emission | 20 dBA |
