Kingston takes Secure Digital to the extreme edge
Kingston's SDHC Ultimate X Class 10 is designed for amateur and professional photographers who need faster speeds to keep pace with their evolving equipment. It allows users to easily capture sequential shots that used to be a challenge due to the speed limitations of memory cards.
Use Kingston's SDHC Ultimate X Class 10 with your digital camera and you'll never miss a shot, whether you're photographing your favorite musician in concert or taking photos on vacation in the Caribbean.
For added reliability and durability, our solid-state SDHC memory cards are built of nonvolatile memory components and have no moving parts that could wear out or break. All cards are 100-percent tested and are backed by a lifetime warranty and 24/7 live technical support.
Product Description | Kingston Ultimate X - flash memory card - 16 GB - SDHC | Product Type | Flash memory card | Form Factor | SDHC Memory Card | Storage Capacity | 16 GB | Speed Rating | Class 10 - 100x | Supply Voltage | 3.3 V | Manufacturer Warranty | Limited lifetime warranty |
General | |
Memory | |
Speed Rating | 100x |
Speed Class | Class 10 |
Read Rate | Up to 20 MB/s |
Write Rate | Up to 15 MB/s |
Features | Write protection switch |
Miscellaneous | |
Compliant Standards | Plug and Play |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Dimensions & Weight | |
Width | 24 mm |
Depth | 32 mm |
Height | 2.1 mm |
Weight | 2.5 g |
Environmental Parameters | |
Min Operating Temperature | -25 °C |
Max Operating Temperature | 85 °C |
