Kingston is the world's largest independent memory manufacturer. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
Product Description | Kingston - DDR2 - module - 2 GB - DIMM 240-pin - 667 MHz / PC2-5300 - unbuffered | Product Type | Memory module | Capacity | 2 GB | Memory Type | DDR2 SDRAM - DIMM 240-pin | Upgrade Type | System specific | Data Integrity Check | Non-ECC | Speed | 667 MHz (PC2-5300) | Features | Unbuffered | OEM Manufacturer Equivalent Part Number | IBM 73P4985, IBM 41X4257, IBM 43R2002, IBM 30R5127 | Manufacturer Warranty | Limited lifetime warranty (Germany, Austria and France - 10 years) |
General | |
Capacity | 2 GB |
Memory | |
Type | DRAM memory module |
Technology | DDR2 SDRAM |
Form Factor | DIMM 240-pin |
Expansion / Connectivity | |
Compatible Slots | 1 x memory - DIMM 240-pin |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty (Germany, Austria and France - 10 years) |
