Kingston's DataTraveler microDuo 3C has a dual interface that works with both standard USB and USB Type-C ports, making it ideal for devices such as smartphones, tablets, PCs and Macs.
Product Description | Kingston DataTraveler microDuo 3C - USB flash drive - 16 GB | Product Type | USB flash drive | Interface Type | USB 3.1 / USB-C | Storage Capacity | 16 GB | OS Required | Linux Kernel 2.6.x or later, Microsoft Windows Vista SP2, Microsoft Windows 7 SP1, Google Chrome OS, Windows 8, Windows 8.1, Windows 10, Apple MacOS X 10.8.x or later | Manufacturer Warranty | 5-year warranty |
General | |
Memory | |
Read Rate | Up to 100 MB/s |
Write Rate | Up to 10 MB/s |
Features | USB On-The-Go compatible, swivel cap |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Dimensions & Weight | |
Width | 29.94 mm |
Depth | 16.6 mm |
Height | 8.44 mm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
