Kingston's DataTraveler R3.0 G2 USB flash drive delivers USB 3.0 high-speed performance with speeds of 120 MB/s read and 45 MB/s write to save time when transferring files. It's 8 times faster than a standard 2.0 drive and saves an estimated 20 minutes when transferring a 1080p Full HD video. Its impressive speeds alleviate transfer bottleneck when storing or viewing HD video, music libraries, digital artwork, presentations and other large files.
With its rugged, rubberized casing, DTR30G2 is certified shock- and water-resistant so it can withstand knocks and bumps without damage while on the go.
Product Description | Kingston DataTraveler R3.0 G2 - USB flash drive - 64 GB | Product Type | USB flash drive | Interface Type | USB 3.0 | Storage Capacity | 64 GB | OS Required | Linux 2.6.x or later, Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Apple MacOS X 10.6.x or later, Microsoft Windows 7 SP1, Windows 8, Windows 8.1, Windows RT | Manufacturer Warranty | 5-year warranty |
General | |
Memory | |
Read Rate | Up to 120 MB/s |
Write Rate | Up to 45 MB/s |
Features | Shockproof, water resistant, rubberised |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Dimensions & Weight | |
Width | 56 mm |
Depth | 22 mm |
Height | 9.2 mm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
