Kingston DataTraveler 100 G2 - USB flash drive - 32 GB - USB 2.0 - black
Key features
  • Convenient - pocket-sized for easy transportability
  • Simple - just Plug and Play into a USB port
  • Practical - capless, USB connector protected within case
Product codes
chevron icon
chevron icon
DataTraveler 100 G2 is a stylish drive built with simplicity in mind, allowing you to focus on your data. High quality components maintain the legendary Kingston reliability and the USB connector is safely housed inside the sleek and durable case. Carry all of your documents with you, wherever you go.
Built with simplicity in mind, DataTraveler 100 features a sliding capless design with the USB connector safely housed inside the sleek case, so you won't worry about losing a cap. DataTraveler 100 is available in large capacities to give you plenty of room for all your documents, photos, MP3 files and video clips.
chevron icon
Product Description Kingston DataTraveler 100 G2 - USB flash drive - 32 GB
Product Type USB flash drive
Interface Type USB 2.0
Storage Capacity 32 GB
Enclosure Colour Black
OS Required Microsoft Windows 2000 SP4, Linux 2.6.x or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5.x or later
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
