ITEM | QTY | PRICE |
Logitech M187 Wireless Mini Mouse White
4 | £69.04 |
DataTraveler 100 G2 is a stylish drive built with simplicity in mind, allowing you to focus on your data. High quality components maintain the legendary Kingston reliability and the USB connector is safely housed inside the sleek and durable case. Carry all of your documents with you, wherever you go.
Built with simplicity in mind, DataTraveler 100 features a sliding capless design with the USB connector safely housed inside the sleek case, so you won't worry about losing a cap. DataTraveler 100 is available in large capacities to give you plenty of room for all your documents, photos, MP3 files and video clips.
Product Description | Kingston DataTraveler 100 G2 - USB flash drive - 16 GB | Product Type | USB flash drive | Interface Type | USB 2.0 | Storage Capacity | 16 GB | Enclosure Colour | Black | OS Required | Microsoft Windows 2000 SP4, Linux 2.6.x or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5.x or later | Manufacturer Warranty | 5-year warranty |
General | |
Memory | |
Read Rate | Up to 10 MB/s |
Write Rate | Up to 5 MB/s |
Features | Retractable connector |
Miscellaneous | |
Compliant Standards | Plug and Play |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Dimensions & Weight | |
Width | 69.6 mm |
Depth | 22.4 mm |
Height | 12.8 mm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
