Kingston - DDR3L - 8 GB - DIMM 240-pin - 1600 MHz / PC3L-12800 - CL11 - 1.35 V - unbuffered - ECC
Product Description | Kingston - DDR3L - module - 8 GB - DIMM 240-pin - 1600 MHz / PC3L-12800 - unbuffered | Product Type | Memory module | Capacity | 8 GB | Memory Type | DDR3L SDRAM - DIMM 240-pin | Upgrade Type | Generic | Data Integrity Check | ECC | Speed | 1600 MHz (PC3L-12800) | Latency Timings | CL11 | Features | Dual rank, Low Voltage, unbuffered | Voltage | 1.35 V | Lead Plating | Gold | Manufacturer Warranty | Limited lifetime warranty (Russia - 10 years) |
General | |
Capacity | 8 GB |
Memory | |
Type | DRAM memory module |
Technology | DDR3L SDRAM |
Form Factor | DIMM 240-pin |
Module Configuration | 1024 X 72 |
Chips Organization | X8 |
Voltage | 1.35 V |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty (Russia - 10 years) |
