Kingston 8GB 1600MHz ECC Low Voltage Module
Product codes
chevron icon
chevron icon
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
chevron icon
Product Description Kingston - DDR3L - module - 8 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
Product Type Memory module
Capacity 8 GB
Memory Type DDR3L SDRAM - DIMM 240-pin
Upgrade Type System specific
Data Integrity Check ECC
Speed 1600 MHz (PC3-12800)
Latency Timings CL11
Features Low Voltage, unbuffered
Voltage 1.35 V
Lead Plating Gold
OEM Manufacturer Equivalent Part Number IBM 0C19500
Designed For Lenovo ThinkServer RS140 70F2, 70F3, 70F8, 70F9; TS130 1098, 1100, 1105, 1106; TS140 70A0, 70A1, 70A4, 70A5; TS430 0387, 0388, 0389, 0390, 0391, 0392, 0393, 0441; TS440 70AL, 70AM, 70AN, 70AQ
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
