ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Product Description | Kingston ValueRAM - DDR3 - kit - 8 GB: 2 x 4 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered | Product Type | Memory kit | Capacity | 8 GB: 2 x 4 GB | Memory Type | DDR3 SDRAM - DIMM 240-pin | Upgrade Type | Generic | Data Integrity Check | Non-ECC | Speed | 1333 MHz (PC3-10600) | Latency Timings | CL9 | Features | Single rank, unbuffered | Voltage | 1.5 V | Lead Plating | Gold | Manufacturer Warranty | Limited lifetime warranty |
General | |
Memory | |
Type | DRAM memory kit |
Technology | DDR3 SDRAM |
Form Factor | DIMM 240-pin |
Module Height (inch) | 1.18 |
Module Configuration | 512 x 64 |
Chips Organization | X8 |
Voltage | 1.5 V |
Expansion / Connectivity | |
Compatible Slots | 2 x memory - DIMM 240-pin |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
