It's easy to find the Flash memory, USB drives and accessories to maximize your mobile device. Kingston Flash memory products feature fast speeds, large capacities and impressive performance. Kingston Flash memory - it's for you.
Product Description | Kingston Multi-Kit / Mobility Kit - flash memory card - 64 GB - microSDXC UHS-I | Product Type | Flash memory card | Bundled with | USB Reader | Form Factor | microSDXC UHS-I Memory Card | Storage Capacity | 64 GB | Speed Rating | UHS Class 1 / Class10 | Included Memory Adapter | microSDXC to SD adapter | OS Required | Linux 2.6.x or later, Microsoft Windows Vista, Apple MacOS X 10.6.x or later, Microsoft Windows 7 SP1, Windows 8, Windows 8.1 | Manufacturer Warranty | Limited lifetime warranty |
General | |
Memory | |
Speed Class | UHS Class 1 / Class10 |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Dimensions & Weight | |
Width | 11 mm |
Depth | 15 mm |
Thickness | 1 mm |
Environmental Parameters | |
Min Operating Temperature | -25 °C |
Max Operating Temperature | 85 °C |
