Kingston's SSDNow V300 solid-state drive is a cost-effective way to revive your computer. It's 10x faster than a hard drive plus more reliable, more durable and shock-proof. It features an LSI SandForce controller customized for Kingston and best-in-class components, and is available in kits with all the accessories needed for an effortless transition to the latest technology. For added peace of mind, it's backed by a three-year warranty, free technical support and legendary Kingston reliability.
Compressible Data Transfer (ATTO)
Incompressible Data Transfer (AS-SSD and CrystalDiskMark)
IOMETER Maximum Random 4k Read/Write
PCMARK® Vantage HDD Suite Score
Product Description | Kingston SSDNow V300 - SSD - 60 GB - SATA 6Gb/s | Type | Solid state drive - internal | Capacity | 60 GB | Form Factor | 2.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Features | Shock resistant | Dimensions (WxDxH) | 69.8 mm x 100.1 mm x 7 mm | Weight | 86 g | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Solid state drive - internal |
Capacity | 60 GB |
Width | 69.8 mm |
Depth | 100.1 mm |
Height | 7 mm |
Weight | 86 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 450 MBps (read) / 450 MBps (write) |
Maximum 4KB Random Write | 60000 IOPS |
Reliability | |
MTBF | 1,000,000 hours |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s - 7 pin Serial ATA |
Compatible Bay | 2.5" |
Power | |
Power Consumption | 2.052 Watt (active) , 0.64 Watt (idle) |
Miscellaneous | |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Technical support |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Vibration Tolerance | 2.17 g @ 7-800 Hz (operating) / 20 g @ 10-2000 Hz (non-operating) |
