Kingston's KC400 SSD is faster than a hard drive to deliver consistent performance for both compressible and incompressible data and improve responsiveness in performance-hungry applications. It uses a powerful processor to speed up daily tasks and improve productivity. KC400 provides end-to-end data path protection and SmartECC to guard data, plus SmartRefresh to protect against read errors. Data is rebuilt if there's an error, and the drive is able to recover from an unexpected power shutdown, thanks to firmware-controlled power loss management. Advances in controller technology and NAND give this drive excellent data reliability.
Product Description | Kingston SSDNow KC400 - SSD - 512 GB - SATA 6Gb/s | Type | Solid state drive - internal | Capacity | 512 GB | Form Factor | 2.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Features | TRIM support, Phison PS3110-S10 controller, Advanced Smart ECC, Firmware-based Power-Loss Protection, S.M.A.R.T. | Dimensions (WxDxH) | 69.9 mm x 100.1 mm x 7 mm | Weight | 60 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Solid state drive - internal |
Capacity | 512 GB |
Width | 69.9 mm |
Depth | 100.1 mm |
Height | 7 mm |
Weight | 60 g |
Performance | |
SSD Endurance | 800 TB |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 550 MBps (read) / 530 MBps (write) |
4KB Random Read | 86000 IOPS |
4KB Random Write | 88000 IOPS |
Maximum 4KB Random Write | 86000 IOPS |
Maximum 4KB Random Read | 99000 IOPS |
Reliability | |
MTBF | 1,000,000 hours |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s - 7 pin Serial ATA |
Compatible Bay | 2.5" |
Power | |
Power Consumption | 3.74 Watt (active) , 0.255 Watt (idle) , 0.335 Watt (average) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years , Technical support |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Vibration Tolerance (operating) | 2.17 g @ 7-800 Hz |
Vibration Tolerance (non-operating) | 20 g @ 10-2000 Hz |
