Breathe new life into your system
Kingston’s SSDNow UV400 is powered by a four-channel Marvell controller for incredible speeds and higher performance compared to a mechanical hard drive. It dramatically improves the responsiveness of your existing system and is 10 times faster than a 7200RPM hard drive.
Rugged and more reliable and durable than a hard drive, UV400 is built using Flash memory so it’s shock and vibration-resistant and less likely to fail than a mechanical hard drive. Its ruggedness makes it ideal for notebooks and other mobile computing devices.
It’s the ideal hard drive replacement and can also replace a smaller SSD in your system to give you all the room you need.
• 10 times faster than a 7200RPM hard drive
• More reliable and durable than a hard drive
• Multiple capacities to meet your needs
Product Description | Kingston SSDNow UV400 - solid state drive - 480 GB - SATA 6Gb/s | Type | Solid state drive - internal | Capacity | 480 GB | NAND Flash Memory Type | Triple-level cell (TLC) | Form Factor | 2.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Features | Shock resistant, rugged, Marvell 88SS1074 controller | Dimensions (WxDxH) | 69.9 mm x 100 mm x 7 mm | Weight | 57 g | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Solid state drive - internal |
Capacity | 480 GB |
Width | 69.9 mm |
Depth | 100 mm |
Height | 7 mm |
Weight | 57 g |
Performance | |
SSD Endurance | 256 TB |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 550 MBps (read) / 500 MBps (write) |
Maximum 4KB Random Write | 35000 IOPS |
Maximum 4KB Random Read | 90000 IOPS |
Reliability | |
MTBF | 1,000,000 hours |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s - 7 pin Serial ATA |
Compatible Bay | 2.5" |
Power | |
Power Consumption | 0.693 Watt (average) , 0.672 Watt (idle) , 0.59 Watt (read) , 2.515 Watt (write) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Technical support |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Vibration Tolerance (operating) | 2.17 g @ 7-800 Hz |
Vibration Tolerance (non-operating) | 20 g @ 10-2000 Hz |
