Maximize footage from your drone, GoPro or Ultra HD camera with Kingston's Gold microSD UHS-I Speed Class 3 (U3) card. Shoot footage at up to 30 frames per second in 4K and capture 120 frames per second in 1080P HD. Increased write speeds let you shoot in continuous burst mode and higher sustained write speeds ensure video integrity by reducing stutter. Suitable for the most extreme conditions.
Product Description | Kingston Gold - flash memory card - 32 GB - microSDHC UHS-I | Product Type | Flash memory card | Form Factor | microSDHC UHS-I Memory Card | Storage Capacity | 32 GB | Speed Rating | UHS-I U3 / Class10 | Included Memory Adapter | microSDHC to SD adapter | Manufacturer Warranty | Limited lifetime warranty |
General | |
Memory | |
Speed Class | UHS-I U3 / Class10 |
Read Rate | Up to 90 MB/s |
Write Rate | Up to 45 MB/s |
Features | Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Dimensions & Weight | |
Width | 11 mm |
Depth | 15 mm |
Thickness | 1 mm |
Environmental Parameters | |
Min Operating Temperature | -25 °C |
Max Operating Temperature | 85 °C |
