Designed specifically for enterprise, government and military customers that need high performance and reliability in their USB flash storage devices, IronKey Basic S250 flash drive meets the extreme performance and security requirements of some even very demanding organizations. It is equipped with strong hardware encryption. A ruggedized, waterproof metal chassis helps protect S250 drive from the elements, and active anti-malware prevents USB threats from spreading.
Product Description | IronKey Basic S250 - USB flash drive - 2 GB | Product Type | USB flash drive | Interface Type | USB 2.0 | Storage Capacity | 2 GB | Hardware Encryption | Yes | Encryption Algorithm | FIPS 140-2 Level 3, 2048-bit RSA, 256-bit SHA, 256-bit AES-CBC | Technology | SLC NAND Flash | OS Required | Microsoft Windows Vista SP2, Linux 2.6 or later, Microsoft Windows 7 SP1, Windows 8, Windows 8.1 / 10, Apple MacOS X 10.9.x - 10.11.x | Manufacturer Warranty | 5-year warranty |
General | |
Memory | |
Read Rate | Up to 31 MB/s |
Write Rate | Up to 24 MB/s |
Features | Password protection, waterproof, tamper-proof, ruggedized, metal body, Cryptochip |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Dimensions & Weight | |
Width | 75 mm |
Depth | 19 mm |
Height | 9 mm |
Weight | 25 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
