Designed specifically for enterprise, government and military customers that need high performance and reliability in their USB flash storage devices, IronKey Basic S250 and D250 flash drives meet the stringent Security Level 3 requirements of the FIPS 140-2 standard. IronKey Basic S250 and D250 drives meet the extreme performance and security requirements of some of the world’s most demanding organizations and are built from the ground up to be the world’s most secure flash drives. They’re equipped with strong hardware encryption and use the algorithm approved by the DOD for storing Top Secret data. A ruggedized, waterproof metal chassis helps protect S250 and D250 drives from the elements, and active anti-malware prevents USB threats from spreading. IronKey Basic S250 and D250 drives are equipped with a control panel localized into eight languages around the world.
Product Description | IronKey Basic S250 - USB flash drive - 16 GB | Product Type | USB flash drive | Interface Type | USB 2.0 | Storage Capacity | 16 GB | Hardware Encryption | Yes | Encryption Algorithm | FIPS 140-2 Level 3, 256-bit AES, 2048-bit RSA, 256-bit SHA | Technology | SLC NAND Flash | OS Required | Microsoft Windows Vista SP2, Linux 2.6 or later, Microsoft Windows 7 SP1, Windows 8, Apple MacOS X 10.9 - 10.11, Windows 8.1 / 10 | Manufacturer Warranty | 5-year warranty |
General | |
Memory | |
Read Rate | Up to 31 MB/s |
Write Rate | Up to 24 MB/s |
Features | Password protection, waterproof, tamper-proof, ruggedized, metal body, Cryptochip |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Dimensions & Weight | |
Width | 75 mm |
Depth | 19 mm |
Height | 9 mm |
Weight | 25 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
