Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Product Description | Kingston - DDR3 - module - 16 GB - DIMM 240-pin - 1866 MHz / PC3-14900 - registered | Product Type | Memory module | Capacity | 16 GB | Memory Type | DDR3 SDRAM - DIMM 240-pin | Upgrade Type | System specific | Data Integrity Check | ECC | Speed | 1866 MHz (PC3-14900) | Latency Timings | CL13 | Features | Registered | Voltage | 1.5 V | Lead Plating | Gold | OEM Manufacturer Equivalent Part Number | Cisco UCS-MR-1X162RZ-A | Manufacturer Warranty | Limited lifetime warranty | Designed For | UCS C220 M3, C240 M3 |
General | |
Capacity | 16 GB |
Memory | |
Type | DRAM memory module |
Technology | DDR3 SDRAM |
Form Factor | DIMM 240-pin |
Module Configuration | 2048 x 72 |
Voltage | 1.5 V |
Expansion / Connectivity | |
Compatible Slots | 1 x memory - DIMM 240-pin |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
Designed For | Cisco MXA UCS C220 M3 Rack Server for Cisco Show and Share Enterprise, C220 M3 Rack Server for Cisco Show and Share Workgroup , Cisco UCS B200 M3 Blade Server, B420 M3 Blade Server, B420 M3 Blade Server (Not a standalone SKU), B420 M3 Value SmartPlay Expansion Pack, B420 M3 Value SmartPlay Solution, C220 M3 Entry 1 Rack Server, C220 M3 Entry 2 Rack Server, C220 M3 Entry Smart Play, C220 M3 High-Density Rack Server Large Form Factor Hard Disk Drive, C220 M3 High-Density Rack-Mount Server Small Form Factor, C220 M3 High-Density Rack-Mount Server Small Form Factor (Not a standalone SKU), C220 M3 Perform 1 Rack Server, C220 M3 Perform 2 Rack Server, C220 M3 Performance Smart Play, C220 M3 Scale Smart Play, C220 M3 Small Form Factor, C220 M3 Small Form Factor Business Edition, C220 M3 Value 1 Rack Server, C220 M3 Value 2 Rack Server, C220 M3 Value Smart Play, C240 M3 Entry 1 Rack Server, C240 M3 Entry 2 Rack Server, C240 M3 Entry SmartPlay, C240 M3 High-Density Rack Server (Large Form Factor Hard Disk Drive Model), C240 M3 High-Density Rack-Mount Server Small Form Factor, C240 M3 Perform 1 Rack Server, C240 M3 Perform 2 Rack Server, C240 M3 Performance Smart Play, C240 M3 Scale Smart Play, C240 M3 Value 1 Rack Server, C240 M3 Value 2 Rack Server, C240 M3 Value Smart Play, Managed C240 M3 High-Density Rack-Mount Server Small Form Factor, Smart Play 8 B420 M3 Value Expansion Pack, SmartPlay Select C3260 Basic, SmartPlay Select C3260 Basic Plus, SmartPlay Select C3260 Entry, SmartPlay Select C3260 Entry Plus, SmartPlay Select C3260 Performance, SmartPlay Select C3260 Performance Plus, SmartPlay Select C3260 Seed, SmartPlay Select C3260 Value |
