HyperX® Predator memory has the fastest speeds, lowest latencies and highest capacities available in HyperX memory. It’s designed for and compatible with all popular brands of motherboards. HyperX Predator is ultra-reliable and 100 per cent factory tested to ensure that it will deliver higher performance, ultraresponsive multitasking and a faster system.Predator features a tall heat spreader for greater heat dissipation, and its black PCB complements the look and design of the latest PC hardware. Intel XMP-certified kits are available up to 2800MHz. Users can overclock their platforms simply by selecting a profile, with no need for manual adjustments in BIOS.For added peace of mind, HyperX Predator is backed by a lifetime warranty, free technical support and legendary reliability.
Product Description | HyperX Predator - DDR3 - kit - 16 GB: 2 x 8 GB - DIMM 240-pin - 1866 MHz / PC3-14900 - unbuffered | Product Type | Memory kit | Capacity | 16 GB: 2 x 8 GB | Memory Type | DDR3 SDRAM - DIMM 240-pin | Upgrade Type | Generic | Data Integrity Check | Non-ECC | Speed | 1866 MHz (PC3-14900) | Latency Timings | CL9 (9-10-11) | Features | Heat sink, dual rank, eight banks, Serial Presence Detect (SPD), Intel Extreme Memory Profiles (XMP), unbuffered | Voltage | 1.5 V | Lead Plating | Gold | Manufacturer Warranty | Limited lifetime warranty (Russia - 10 years) |
General | |
Memory | |
Type | DRAM memory kit |
Technology | DDR3 SDRAM |
Form Factor | DIMM 240-pin |
Module Height (inch) | 1.614 |
Module Configuration | 1024 x 64 |
Chips Organization | 512 x 8 |
Voltage | 1.5 V |
RAM Performance | SPD - 1600 MHz - 1.5 V - CL11 - 11-11-11 , Intel Extreme Memory Profiles (XMP) - 1600 MHz - 1.5 V - CL9 - 9-9-9 , Intel Extreme Memory Profiles (XMP) - 1866 MHz - 1.5 V - CL9 - 9-10-11 |
Miscellaneous | |
Colour Category | Black |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty (Russia - 10 years) |
