ITEM | QTY | PRICE |
BT London South East
3 | £30.00 |
Kingston's Canvas Select Plus SD card is designed with exceptional performance, speed, and durability for heavy workloads such as transferring and developing high-resolution photos or capturing and editing full HD videos. It can reach Class 10 UHS-I speeds up to 100MB/s for easy storage and quick transfers along with an advanced UHS-I interface that can record cinematic Full HD and 4K Ultra HD videos. The Canvas Select Plus SD card is built to perform in the harshest environments and conditions so you can take it anywhere knowing your files, photos, and videos are protected.
Product Description | Kingston Canvas Select Plus - flash memory card - 128 GB - SDXC UHS-I | Product Type | Flash memory card | Form Factor | SDXC UHS-I Memory Card | Storage Capacity | 128 GB | Speed Rating | Video Class V30 / UHS-I U3 / Class10 | Manufacturer Warranty | Limited lifetime warranty |
General | |
Memory | |
Speed Class | Video Class V30 / UHS-I U3 / Class10 |
Read Rate | Up to 100 MB/s |
Write Rate | Up to 85 MB/s |
Features | Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Dimensions & Weight | |
Width | 24 mm |
Depth | 32 mm |
Height | 2.1 mm |
Environmental Parameters | |
Min Operating Temperature | -25 °C |
Max Operating Temperature | 85 °C |
