The wired ValuMouse features a three-button/scroll wheel setup that offers silent clicking when you need to get work done and don't want to disturb anyone in a quiet environment. A high-definition optical sensor provides reliable and responsive control when you're navigating and the comfortable, contoured shaping feels great for either right-handed or left-handed users. It offers Plug & Play installation with a standard USB wired connection.
Product Description | Kensington ValuMouse - mouse - USB - black | Device Type | Mouse | Connectivity Technology | Wired - USB | Colour | Black | Orientation | Right and left-handed | Dimensions (WxDxH) | 6 cm x 10.8 cm x 3.8 cm | Weight | 90 g | Movement Detection Technology | Optical | Buttons Qty | 3 | Movement Resolution | 1000 dpi | Features | Scrolling wheel, ambidextrous design | OS Required | Apple MacOS X 10.5 - 10.8, Microsoft Windows 7 / 8 / 8.1 / 10 | Manufacturer Warranty | 5-year warranty |
General | |
Width | 6 cm |
Depth | 10.8 cm |
Height | 3.8 cm |
Weight | 90 g |
Colour | Black |
Input Device | |
Connectivity Technology | Wired |
Interface | USB |
Buttons Qty | 3 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Compliant Standards | Plug and Play |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
