Let the leader in professional desktop performance make your transition to USB-C connectivity as smooth as possible with the SD4600 USB-C Universal Dock with Power Delivery. The dock works with Windows , Mac OS and Chrome OS devices, allowing you to plug in a single cable that delivers 4K video, charges your laptop and offers high-speed data transfer. Plus, you get instant access to all your peripheral desktop accessories. Zero Footprint mounting makes it ideal for workstations with limited space (mount sold separately) and its Thunderbolt 3 compatible.
Product Description | Kensington SD4600P USB-C Universal Dual 4K Dock w/ 60W PD - Win/Chrome/Mac - docking station - USB-C - HDMI - GigE | Product Type | Docking station | Docking Interface | USB-C | Video Interfaces | HDMI | Dimensions (WxDxH) | 23.5 cm x 14.6 cm x 9.35 cm | Networking | Gigabit Ethernet | Power | Power adapter DC 20 V | Manufacturer Warranty | 3-year warranty |
General | |
Width | 23.5 cm |
Depth | 14.6 cm |
Height | 9.35 cm |
Networking | |
Data Link Protocol | Gigabit Ethernet |
Expansion / Connectivity | |
Interfaces | 1 x video - HDMI - 19 pin HDMI Type A , 1 x video - DisplayPort , 1 x USB-C - 24 pin USB-C , 3 x USB 3.1 - 19 pin USB 3.1 header , 1 x audio - line-in/headphones - mini-phone 3.5 mm , 1 x audio - line-in/microphone - mini-phone 3.5 mm , 1 x network - 1000Base-T - RJ-45 |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), dual monitor support, 4K Ultra HD |
Security Slot Type | Kensington security slot |
Compliant Standards | Plug and Play |
Power | |
Power Device | Power adapter |
Voltage Required | DC 20 V |
System Requirements | |
OS Required | Google Chrome OS, Apple MacOS X 10.10, Apple MacOS X 10.11, Windows 8.1 / 10 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
