The MicroSaver lock head features the patented T-bar locking mechanism. The T-bar provides a tight fit with the Kensington Security Slot. A rubber bumper ensures a snug fit between the lock and the security slot and protects your hardware. A further deterrent is the tamper evident feature. When a Kensington MicroSaver lock is tampered with, it locks itself down and can even trap foreign keys.
All Kensington locks are built to exacting engineering standards. This lock is rated as Safe Pro, a rating awarded to Kensington Security Locks that are tested under stringent test conditions by third party testing agencies for their ability to withstand attacks.
We provide two keys with each standard lock. Each key is stamped with a unique code. Register your code online and well be able to send you a replacement key.
Our business is protecting yours
Kensington locks are made with high-carbon steel cables and tested under rigorous real-world conditions to resist lock-picking, corro.
Product Description | Kensington MicroSaver - security cable lock | Product Type | Security cable lock | Package Content | Security cable | Dimensions (WxDxH) | 0.53 cm x 180 cm x 0.53 cm | Weight | 250 g | Features | Key lock, T- bar lock | Package Type | Retail | Manufacturer Warranty | Limited lifetime warranty |
General | |
Width | 0.53 cm |
Depth | 180 cm |
Height | 0.53 cm |
Weight | 250 g |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | Limited warranty: - lifetime |
The following resources are available for the Kensington Slim MicroSaver Security Kit
