We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The Jabra Link 260 extends the capability of your Jabra corded QD (Quick Disconnect) headset, provides call control and enhances the audio at the same time. With the plug-and-play USB adapter, you can use your Jabra deskphone headset together with your softphone. The Digital Signal Processing (DSP) technology evens out the audio stream to ensure a clear sound on both ends of the call.
Product Description | Jabra LINK 260 - headset adapter | Cable | Headset adapter | Connector | USB - male | Connector (Second End) | Quick Disconnect | Features | In-cord volume control, answer/end button, mute switch, Digital Signal Processing (DSP) technology, acoustic shock protection, programmable buttons | Designed For | BIZ 2300 Duo, 2300 MS QD Mono, 2300 QD Mono, 2400 Duo, 2400 Mono Headband |
General | |
Cable Type | Headset adapter |
Connectivity | |
Connector | 4 pin USB Type A - male |
Miscellaneous | |
Compliant Standards | Plug and Play, Directive 2003/10/CE |
Compatibility Information | |
Designed For | Jabra BIZ 2300 Duo, 2300 MS QD Mono, 2300 QD Mono, 2400 Duo, 2400 Mono Headband |
