The Jabra Evolve 30 is a professional headset, designed to improve conversations. Excellent speakers are built for both voice and music. Switch easily between conversations and listening to your favorite tracks. Simply wear the headset to eliminate high-frequency noise, such as human voices, - all thanks to the specially designed ear cushions. In-line call controller gives you easy access with large buttons and LED indicators. Pick up or end calls, control volume, or simply mute the line.
Jabra Evolve 30 with 3.5 mm jack
In response to popular demand, Jabra is proud to announce the new upgraded Jabra Evolve 30 now with a new USB call control unit with integrated 3.5 mm jack for connectivity to smart devices.
Help your customers speed up their UC adoption with the user friendly Jabra Evolve 30.
Product Description | Jabra Evolve 30 II UC Mono - headset | Product Type | Headset - wired - 3.5 mm jack | Recommended Use | Portable electronics, computer - communication | Headphones Form Factor | On-ear | Connectivity Technology | Wired | Sound Output Mode | Mono | Sound Effects | Crystal Clear | Audio Specifications | Frequency Response 150 - 7000 Hz - Sensitivity 93.6 dB | Impedance | 32 Ohm | Max Input Power | 10 mW | Microphone | Boom | Microphone Technology | Electret condenser | Microphone Noise Cancelling | Yes | Controls | Mute, volume, answer/end | Manufacturer Warranty | 2-year warranty |
General | |
Earpad Material | Leatherette |
Audio Output | |
Frequency Response | 150 - 7000 Hz |
Sensitivity | 93.6 dB |
Diaphragm | 28 mm |
In-Cord Volume Control | Yes |
Adjustable Headband | Yes |
Features | PeakStop technology |
Microphone | |
Type | Boom |
Form Factor | Headset microphone |
Sensitivity | -44 dB |
Frequency Response | 100 - 10000 Hz |
Audio Input Details | - 100 - 10000 Hz |
Remote Control | |
Cable | |
Cable Length | 1.2 m |
Miscellaneous | |
Included Accessories | Carrying pouch |
Cable Details | Headset cable - 1.2 m , USB control cable - detachable - 95 cm |
Compliant Standards | Plug and Play, UL, FCC, KCC, RCM |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight (Shipping) | |
Shipping Width | 18 cm |
Shipping Depth | 23 cm |
Shipping Height | 3.5 cm |
Shipping Weight | 142.5 g |
