Your contact centre agents are your brand ambassadors, so give them the tool to sound as clear as your brand. In Jabra's Biz 2300, world-class sound meets world-class durability in an exceptionally comfortable and stylish corded headset – keeping both your agents and your customers happy.Jabra Biz 2300 USB Microsoft Lync Duo is a stereo headset that provides USB connectivity optimised for Microsoft Lync.
Jabra BIZ 2300 USB Microsoft Lync Mono provides USB connectivity optimized for Microsoft Lync in contact center environments.
Better conversations for the contact centre
Your contact centre agents are your brand's front line. Jabra BIZ 2300 will ensure every customer conversation becomes a great brand experience. This new corded headset features HD Voice/Wideband speaker performance and best-in-class noise-cancellation.
Keep your contact centre agents happy
The Jabra BIZ 2300 for contact centres blends a lightweight yet durable construction with an unobtrusive, professional Scandinavian design aesthetic. The Jabra BIZ 2300 works hard, looks great and is designed for easy daily handling. It is a headset built to be comfortable all day long.
The contact centre headset that is built to last
Jabra BIZ 2300 is built with total cost of ownership in mind. Beside 360° degree rotating break-proof boom-arm and Kevlar-reinforced cord, the Jabra BIZ 2300 is built to withstand any punishment a high-performing contact centre can give.
A UC headset with easy in-line call management
The Jabra BIZ 2300 is a UC headset that features an intuitive, in-line call controller for greater productivity and convenience. Large buttons with LED indicators make it easy for agents to pick up or end calls, put callers on or take them off hold, set volume levels or put the call on mute. Plus, all buttons are user-programmable.
Product Description | Jabra BIZ 2300 USB MS Duo - headset | Product Type | Headset - wired - USB | Recommended Use | Computer - communication | Headphones Form Factor | On-ear | Connectivity Technology | Wired | Sound Output Mode | Stereo | Audio Specifications | Frequency Response 70 - 16000 Hz - Sensitivity 93 dB | Impedance | 32 Ohm | Max Input Power | 10 mW | Microphone | Boom | Microphone Noise Cancelling | Yes | Controls | Mute, volume, answer/end, hold, programmable button |
General | |
Weight | 68 g |
Body Material | PC/ABS, Luran |
Earpad Material | Leatherette, foam |
Protection | Breath-resistant |
Audio Output | |
Frequency Response | 70 - 16000 Hz |
Sensitivity | 93 dB |
Diaphragm | 28 mm |
In-Cord Volume Control | Yes |
Adjustable Headband | Yes |
Features | PeakStop technology, FreeSpin technology |
Microphone | |
Type | Boom |
Form Factor | Headset microphone |
Sensitivity | -30 dB |
Frequency Response | 101 - 10000 Hz |
Audio Input Details | Uni-directional - 101 - 10000 Hz |
Remote Control | |
Connections | |
Connector Type | Headset (4 PIN USB Type A) |
Cable | |
Cable Length | 2.35 m |
Miscellaneous | |
Cable Details | Headset cable - Kevlar reinforced - 2.35 m |
Compliant Standards | UL, cUL, FCC, RoHS, KCC, REACH, EAC, RCM, G616 |
The following resources are available for the Jabra BIZ 2300 Duo USB MS Lync Headset
