Get ready for truly responsive performance. The Intel® NUC Kit NUC7i5BNH is built with a dual-core 7th Generation Intel® Core™ i5 processor. So you’ve got the performance to turn the Intel® NUC into a powerhouse of productivity and play, streaming your favorite movies and music, or running analytics. With dual-array front microphones, you can take full advantage of Windows® 10 and Cortana. Intel® Iris™ Plus graphics transform the viewing experience with 4K Ultra HD video and premium content playback, enabling new ways to enjoy the latest Hollywood blockbusters. And the multi-color LED ring lets you personalize your NUC with the look you want—making it at home in the living room, den, office, or any place you can imagine. Room for up to 32 GB of DDR4 RAM lets you increase performance easily. Also features a 2.5" drive bay for an SSD or HDD with up to 2 TB of storage space.
Pint-sized Power
The Intel® NUC is a mini PC with the power of a desktop, packing features for entertainment, gaming, and productivity in a 4x4 form factor.
Energy Optimized, Media Savvy
With Intel® NUC, you get an immersive media experience and responsive interaction while consuming a small amount of power relative to a full-sized PC.
Product Description | Intel Next Unit of Computing Kit NUC7I5BNH - mini PC - Core i5 7260U 2.2 GHz - 0 GB - no HDD | Type | PC barebone - mini PC | Processor | 1 x Intel Core i5 (7th Gen) 7260U / 2.2 GHz (, up to 3.4 GHz, (Dual-Core) | Processor Main Features | Intel Virtualization Technology, Intel AES New Instructions | Cache Memory | 4 MB L3 Cache | Cache Per Processor | 4 MB | RAM | 0 GB (installed) / 32 GB (max) - DDR4 SDRAM | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | No HDD | Optical Storage | No optical drive | Card Reader | Yes | Graphics Controller | Intel Iris Plus Graphics 640 | Audio Output | 7.1 channel surround | Networking | 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2 | Dimensions (WxDxH) | 11.5 cm x 11.1 cm x 5.1 cm | Manufacturer Warranty | Limited warranty - 3 years |
General | |
Type | PC barebone |
Product Form Factor | Mini PC |
Built-in Devices | Infrared receiver |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7260U |
Clock Speed | 2.2 GHz |
Max Turbo Speed | 3.4 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Not upgradable |
Cache Memory | |
Installed Size | L3 Cache - 4 MB |
RAM | |
Installed Size | 0 GB / 32 GB (max) |
Technology | DDR4 SDRAM |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 2 (empty) |
Features | Dual channel memory architecture |
Hard Drive | |
Type | No HDD |
Storage Controller | |
Type | SATA |
Controller Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1 |
Optical Storage | |
Type | No optical drive |
Card Reader | |
Type | Card reader |
Supported Flash Memory Cards | SDXC UHS-I Memory Card |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel Iris Plus Graphics 640 |
Video Interfaces | HDMI, DisplayPort |
Max Monitors Supported | 3 |
Audio Output | |
Sound Output Mode | 7.1 channel surround |
Compliant Standards | High Definition Audio |
Networking | |
Ethernet Controller | Intel I219-V |
Wireless LAN Supported | Yes |
Wireless NIC | Intel Dual Band Wireless-AC 8265 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
Expansion / Connectivity | |
Bays | 1 (total) / 1 (free) x internal M.2 2242/2280 , 1 (total) / 1 (free) x internal 2.5" |
Slots | 2 (total) / 2 (free) x SO-DIMM 260-pin |
Interfaces | 4 x USB 3.0 - Type A (2 front, 2 rear) (one of them is fast-charging) , 2 x USB 2.0 (2 internal) , 1 x HDMI , 1 x headphones/microphone - mini-jack , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x Thunderbolt 3/DisplayPort/USB-C 3.1 Gen 2 , 2 x SATA-600 (2 internal) |
Miscellaneous | |
Included Accessories | VESA mounting kit, processor badge |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | ICES-003, EN55024, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, AS/NZS 4268, WEEE, FCC CFR47 Part 15 C, FCC CFR47 Part 15 B, VCCI V-3, VCCI V-2, EN 62311, VCCI V-4, Directive 2012/19/EU, Directive 2011/65/EU, KN24, China RoHS, CNS 13438, ETSI EN 301 489-17, KN32, ETSI EN 301 489-1, ETSI EN 301 893, AS/NZS 2772.2, FCC CFR47 Part 15 E, CISPR 32, EN 55032, ETSI EN 301 328, CAN/CSA-C22.2 No. 60950-1 |
Power | |
Device Type | Power adapter |
Power Provided | 65 Watt |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Dimensions & Weight | |
Width | 11.5 cm |
Depth | 11.1 cm |
Height | 5.1 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
