The XDACBL1M is a 1 meter (3.3 ft) SFP+ 10 GbE Direct Attach passive copper cable. The XDACBL1M SFP+ Direct Attach cables offer a highly cost-effective way to connect within racks and across adjacent racks and are fully compatible with the Intel Ethernet Converged Network Adapter X520 Family (X520 product codes: E10G42BTDA, E10G41BFSR, E10G42BFSR, E10G41BFLR). The Intel Ethernet SFP+ Twinaxial Cables are compliant to the latest SFP+ MSA (Multi-source Agreement) with a reduced power budget and lower port cost compared to optical solutions. Intel Ethernet - It Just Works!
Product Description | Intel Ethernet SFP+ Twinaxial Cable XDACBL1M - direct attach cable - 1 m | Type | Direct attach cable | Technology | Twinaxial | Length | 1 m | Connector | SFP+ - male | Connector (Second End) | SFP+ - male | Designed For | Ethernet Converged Network Adapter X520-DA2, X520-SR1, X520-SR2; Ethernet Server Adapter X520-SR2 |
General | |
Network Cable Type | Direct attach cable |
Length | 1 m |
Connectivity | |
Compatibility Information | |
Designed For | Intel Ethernet Converged Network Adapter X520-DA2, X520-SR1, X520-SR2 , Intel Ethernet Server Adapter X520-SR2 |
