ITEM | QTY | PRICE |
Apple 10.9-inch iPad Air Wi-Fi + Cell...
4 | £3,196.00 |
Intel® Optane™ Memory Changes Everything
Intel® Optane™ memory is a smart, adaptable system accelerator for PCs with a 7th Gen Intel® Core™ processor. It provides uncompromising system responsiveness for large capacity storage drives, making everything you do fast, smooth and easy.
Get the Speed. Keep the Capacity.
It’s revolutionary – the first all-new class of memory in 25 years. Intel® Optane™ memory creates a bridge between the DRAM and storage to deliver an intelligent, amazingly responsive computing experience.
Accelerate Your Experience
This game-changing technology intelligently accelerates new 7th Gen Intel® Core™ processor-based systems while affordably maintaining mega-storage capacity, to deliver a responsive computer experience with short boot times, fast application launches, extraordinary gaming, and responsive browsing.
Intelligent System Acceleration
Optimize your computer responsiveness from system boot to application launch. Intel® Optane™ memory is a smart and adaptable system accelerator that adjusts to your computing tasks making everything you do faster, smoother, easier. Its intelligent software automatically learns your computing behaviors to accelerate frequent tasks and customize your computer experience.
Wait Less, Do More
Intel® Optane™ memory in your PC delivers amazing responsiveness so you can start up quickly, search and find files in a snap and save large files with virtually no lag.
Speed up Your Storage
A high-capacity storage device coupled with Intel® Optane™ memory offers the best of both worlds: high speed acceleration and affordable, large storage capacity.
Product Description | Intel Optane Memory Series - solid state drive - 16 GB - PCIe 3.0 x2 (NVMe) | Type | Solid state drive - internal | Capacity | 16 GB | NAND Flash Memory Type | 20nm | Form Factor | M.2 2280 | Interface | PCIe 3.0 x2 (NVMe) | Features | Intel Rapid Storage Technology, Temperature Monitoring and Logging, End-to-end data protection, Rapid Start Technology, 3D XPoint Technology | Dimensions (WxDxH) | 1.5 mm | Weight | 40 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Solid state drive - internal |
Capacity | 16 GB |
Height | 1.5 mm |
Weight | 40 g |
Performance | |
SSD Endurance | 182.5 TB |
Internal Data Rate | 900 MBps (read) / 145 MBps (write) |
4KB Random Read | 190000 IOPS |
4KB Random Write | 35000 IOPS |
Average Latency | 7 µs |
Reliability | |
MTBF | 1,600,000 hours |
Non-Recoverable Errors | 1 per 10^15 |
Expansion & Connectivity | |
Interfaces | 1 x PCI Express 3.0 x2 (NVMe) - M.2 Card |
Compatible Bay | M.2 2280 |
Power | |
Power Consumption | 1 Watt (idle) , 3.5 Watt (active) |
Software & System Requirements | |
OS Required | Windows 10 64-bit Edition |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Shock Tolerance (operating) | 1500 g @ 0.5 ms |
Shock Tolerance (non-operating) | 1500 g @ 0.5 ms |
Vibration Tolerance (operating) | 2.17 g @ 5-800 Hz |
Vibration Tolerance (non-operating) | 3.13 g @ 5-800 Hz |
