With Full HD resolution and projective capacitive 10 point touch technology, the ProLite display delivers seamless and accurate touch response. Featuring VA LED-backlit LCD screen technology, it offers exceptional color performance and wide viewing angles, making it an excellent choice for a vast array of demanding interactive applications. Users can benefit from its hinged stand, allowing the monitor to lay down completely flat for use as a giant tablet. The T2435MSC comes equipped with several video inputs and a USB 2.0 as well as integrated stereo speakers delivering good-quality sound. An ideal screen for interactive digital signage, InStore retail, gaming and interactive presentations purposes.
Product Description | iiyama ProLite T2435MSC-B2 - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" - touchscreen | Energy Class | Class F | Energy Consumption per Year | 35 kWh | Power Consumption (On mode) | 18.9 W | Features | Touch-screen, microphone, camera, USB 2.0 hub | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.272 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 / 12000000:1 (dynamic) | Response Time | 6 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI-D, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | 7H Hard Coating | Voltage | AC 100/240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 57.1 cm x 4.45 cm x 34.75 cm | Weight | 6.2 kg | Compliant Standards | VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Viewable Size | 23.6" |
Built-in Devices | Microphone, camera, USB 2.0 hub |
Panel Type | VA |
Brightness w/touchscreen | 215 cd/m² |
Vertical Refresh Rate | 55 - 75 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese |
Features | Eco-Mode, HID Compliant, X-Res Technology, 10-point multi-touch, blue light reduction, i-Style Color |
Colour | Black |
Weight | 6.2 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1 Watt |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | DVI-D , DisplayPort , HDMI , Headphones , Audio line-in , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , USB 2.0 (Type B) |
Mechanical | |
Tilt Angle | +15/+70 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), built-in adjustable tilt stand |
Cables Included | 1 x DVI cable - DVI-D to DVI-D , 1 x Mini DisplayPort-DisplayPort cable , 1 x audio cable , 1 x USB cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100/240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 18.9 kWh/1000h |
Power Consumption (Typical) | 23 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | Driver |
OS Required | Linux, Microsoft Windows Vista, Microsoft Windows 7 / Windows 8 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
