ITEM | QTY | PRICE |
Logitech USB HEADSET H390
3 | £116.37 |
The T2452MTS lets you browse the web, email and draw while working on multiple screens, docking or typing on the on-screen keyboard. You can scroll and rotate pictures, draw, zoom in and out using certain tap, flick, grab and pincer gestures.
Product Description | iiyama ProLite T2452MTS-B5 - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" - touchscreen | Energy Class | Class A | Energy Consumption per Year | 33 kWh | Power Consumption (On mode) | 23 W | Features | Touch-screen, stylus | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.272 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 12000000:1 (dynamic) | Response Time | 2 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI-D, VGA | Display Position Adjustments | Tilt | Voltage | AC 100 - 240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 55.6 cm x 22.05 cm x 39.3 cm | Weight | 6.7 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Viewable Size | 23.6" |
Panel Type | TN |
Brightness w/touchscreen | 260 cd/m² |
Vertical Refresh Rate | 55 - 75 Hz |
Horizontal Refresh Rate | 24 - 80 kHz |
Horizontal Viewing Angle | +85 / -85 |
Vertical Viewing Angle | +80 / -80 |
Backlight Technology | LED backlight |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese |
Features | HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), Dual Point Optical Touch technology, blue light reduction |
Colour | Black |
Dimensions (WxDxH) | 55.6 cm x 22.05 cm x 39.3 cm - with stand |
Weight | 6.7 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Input | |
Type | Touch-screen, stylus - touchscreen |
Movement Detection Technology | Optical |
Connectivity | |
Interfaces | VGA , DVI-D , HDMI (HDCP) , Headphones , USB |
Mechanical | |
Tilt Angle | -3/+73 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Stand |
Cables Included | 1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x USB cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100 - 240 V (50/60 Hz) |
Power Consumption (Typical) | 18 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | Driver |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 55.6 cm - depth: 5.6 cm - height: 34.7 cm , With stand - width: 55.6 cm - depth: 22.05 cm - height: 39.3 cm - weight: 6.7 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
