ProLite XB2483HSU-B2DP - a 24" LED backlit LCD screen featuring AMVA panel technology, delivers accurate and consistent color reproduction with wide viewing angles. Offering 24 bit 'True Color' and great performance for displaying black and white with the 3000:1 Native Contrast Ratio, means that the Prolite XB2483HSU-B2DP will provide excellent performance for photographic, design and web-design. The monitor features a height adjustable stand with PIVOT function making it also an excellent choice for universities, corporate and financial markets.
Product Description | iiyama ProLite XB2483HSU-B2DP - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Features | USB 2.0 hub | Panel Type | A-MVA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.275 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 / 12000000:1 (dynamic) | Response Time | 4 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 55.25 cm x 23 cm x 38.1 cm | Weight | 5.6 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, TUV GS, DDC-2B, VESA DPMS, DDC/CI, PSE Mark, VCCI Class B, CU |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Viewable Size | 23.8" |
Built-in Devices | USB 2.0 hub |
Vertical Refresh Rate | 55 - 75 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese |
Features | HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), Flicker Free technology |
Colour | Black |
Dimensions (WxDxH) | 55.25 cm x 23 cm x 38.1 cm - with stand |
Weight | 5.6 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DVI-D , DisplayPort , Headphones (mini-jack) , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , Audio line-in (mini-jack) |
Mechanical | |
Tilt Angle | -5/+22 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable , 1 x DisplayPort cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 25 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | Driver |
OS Required | Microsoft Windows 95/98/ME/2000/XP/Vista/7/8/10 |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 55.25 cm - depth: 5.65 cm - height: 33.4 cm , With stand - width: 55.25 cm - depth: 23 cm - height: 38.1 cm - weight: 5.6 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
