ProLite X2380HS is a 23" LED backlit LCD Screen featuring IPS Panel technology which is considered to be the best all round panel type. It offers accurate and consistent color reproduction with wide viewing angles (178°/178°) and great response time (5 ms black-to-black). The ProLite X2380HS is full HD, has a more than 5mln:1 advanced contrast ratio and 250 cd/m2 brightness offering the user a clear and vivid image. An array of inputs including HDMI, DVI and VGA connections ensure compatibility across a range of devices including games consoles and work stations. The X2380HS also has the two integrated speakers and is VESA mountable. It will provide excellent performance for photographic design, web design, and standard office use and in multi-monitor environment.
Product Description | iiyama ProLite X2380HS-1 - LED monitor - Full HD (1080p) - 23" | Device Type | LED-backlit LCD monitor - 23" | Energy Class | Class B | Energy Consumption per Year | 35 kWh | Power Consumption (On mode) | 23.6 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.2652 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 10000000:1 (dynamic) | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI-D, VGA | Speakers | Integrated | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 54.85 cm x 21.35 cm x 38.85 cm | Weight | 5.8 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | DDC-2B, VESA DPMS, TUV Bauart, TUV GM, VCCI Class B |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23" |
Panel Type | IPS |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 24 - 80 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
Controls & Adjustments | Volume, brightness, contrast, H/V position, gamma correction, colour temperature, phase, clock, aspect control |
OSD Languages | English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese |
Features | HDCP, Eco-Mode, Advanced Contrast Ratio (ACR) |
Colour | Black |
Weight | 5.8 kg |
Audio | |
Type | Speakers - stereo - integrated |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DVI-D , HDMI , Headphones |
Mechanical | |
Tilt Angle | -5/+22 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Stand, cable management cover |
Cables Included | 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable |
Power | |
Power Supply | Internal |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 26 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | Driver |
OS Required | Apple MacOS, Microsoft Windows 95/98/ME/2000/XP, Microsoft Windows Vista / 7 / 8 |
Sustainability Information | |
ENERGY STAR Certified | Yes |
