ProLite T2234MSC uses Projective Capacitive Touch Technology, built into an eye catching bezel with edge-to-edge glass. Featuring IPS LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect display for Interactive digital signage. In addition to the superb Full HD image quality, the screen is suitable for demanding environments. It comes with a rugged bezel, which means it is dust and water resistant.
Product Description | iiyama ProLite T2234MSC-B3X - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" - touchscreen | Features | Touch-screen | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.247 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Display Position Adjustments | Tilt | Screen Coating | 6H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 51.75 cm x 21.9 cm x 35.15 cm | Weight | 7.2 kg | Compliant Standards | VCCI, DDC-2B, VESA DPMS, cULus, TUV Bauart, IP65, CU |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Panel Type | IPS |
Brightness w/touchscreen | 220 cd/m² |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 31.5 - 82.3 kHz |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
OSD Languages | Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Dutch, Japanese |
Features | HDCP, Projected Capacitive Touch (P-CAP) technology |
Colour | Black |
Dimensions (WxDxH) | 51.75 cm x 21.9 cm x 35.15 cm - with stand |
Weight | 7.2 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 3 Watt |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Projected capacitive |
Connectivity | |
Interfaces | VGA , DVI-D (HDCP) , USB , Headphones |
Mechanical | |
Tilt Angle | -5/+90 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x USB cable , 1 x audio cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 27 Watt |
Software / System Requirements | |
OS Required | Linux, Microsoft Windows 7 / 8 / 10 |
