Iiyama ProLite T1931SAW-1 LCD touchscreen monitor 9" / 1280 x 1024 - DVI-D, VGA in black with speakers
Product Description | iiyama ProLite T1931SAW-1 - LCD monitor - 19" | Device Type | LCD monitor - 19" - touchscreen | Features | Touch-screen, stereo speakers | Panel Type | TN | Aspect Ratio | 5:4 | Native Resolution | 1280 x 1024 | Pixel Pitch | 0.294 mm | Brightness | 230 cd/m² | Contrast Ratio | 900:1 | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Speakers | Integrated | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 43.2 cm x 39 cm x 21.8 cm | Weight | 6.6 kg | Compliant Standards | VCCI, DDC-2B, VESA DPMS, GOST-R, IP54, TUV Bauart |
General | |
Display Type | LCD monitor / TFT active matrix |
Diagonal Size | 19" |
Built-in Devices | Stereo speakers |
Panel Type | TN |
Vertical Refresh Rate | 75 Hz |
Horizontal Refresh Rate | 80 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Controls & Adjustments | Mute, volume, brightness, contrast, H/V position, input select, phase, H-size |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese |
Colour | Black |
Weight | 6.6 kg |
Audio | |
Type | Speakers - stereo - integrated |
Output Power / Channel | 1 Watt |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Surface acoustic wave |
Connectivity | |
Interfaces | Serial , DVI-D , VGA , Audio line-in , USB |
Mechanical | |
Tilt Angle | 95 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x serial cable , 1 x USB cable |
Security Slot Type | Kensington security slot |
Power | |
Power Supply | External |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 20 Watt |
Power Consumption Stand by / Sleep | 3 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
