ProLite T1531SR is based on the advanced 5-Wire Resistive technology. Price / performance ratio is ideal for the budget conscious user while quality and specification is certainly not compromised. The display inputs include both analog and digital (DVI) with touchscreen connectivity via either USB or RS-232 which offers greater than typical flexibility. A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree angles. Extensive touch utilities allow for 4 point calibration and either 9/25 point linearization.
Product Description | iiyama ProLite T1531SR-W3 - LED monitor - 15" | Device Type | LED-backlit LCD monitor - 15" - touchscreen | Features | Touch-screen | Panel Type | TN | Aspect Ratio | 4:3 | Native Resolution | 1024 x 768 | Pixel Pitch | 0.297 mm | Brightness | 350 cd/m² | Contrast Ratio | 700:1 | Response Time | 8 ms (black-to-white) | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50 - 60 Hz) | Colour | White | Dimensions (WxDxH) - with stand | 35.1 cm x 20.1 cm x 30.6 cm | Weight | 4.8 kg | Compliant Standards | VCCI, DDC-2B, VESA DPMS, CB, cULus, IP54, TUV Bauart |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 15" |
Panel Type | TN |
Brightness w/touchscreen | 350 cd/m² |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 31.5 - 60.2 kHz |
Horizontal Viewing Angle | 140 |
Vertical Viewing Angle | 125 |
Backlight Technology | LED backlight |
Colour Temperature | 9300K, 6500K, 5500K, 7500K |
Controls & Adjustments | Mute, volume, brightness, contrast, H/V position, input select, colour temperature, phase, H-size |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese |
Features | 5-Wire Resistive Touch Screen Technology, a-Si technology |
Colour | White |
Dimensions (WxDxH) | 35.1 cm x 20.1 cm x 30.6 cm - with stand |
Weight | 4.8 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1 Watt |
Input | |
Type | Touch-screen - touchscreen |
Movement Detection Technology | Resistive |
Connectivity | |
Interfaces | DVI-D , VGA (HD-15) , Serial (DB-9) , USB (Type B) , Audio line-in (mini-jack) |
Mechanical | |
Tilt Angle | -5/+90 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x serial cable , 1 x audio cable - 3.5 mm to 3.5 mm , 1 x USB cable - USB Type A to B |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50 - 60 Hz) |
Power Consumption (Typical) | 20 Watt |
Power Consumption Stand by | 2 Watt |
Software / System Requirements | |
Included Software | Driver |
OS Required | Microsoft Windows CE, Linux, Microsoft Windows 2000 / NT4.0, Apple MacOS X, Microsoft Windows 95/98/ME/2000/XP/Vista/7 |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 35.1 cm - depth: 5.9 cm - height: 27.5 cm , With stand - width: 35.1 cm - depth: 20.1 cm - height: 30.6 cm - weight: 4.8 kg |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
