The ProLite P1905S meets the increasing demands for protected LCD's within education, retail and industrial applications. In addition to having toughened safety glass fitted behind the bezel at 8H hardness rating capable of resisting above normal impacts to the display, Iiyama have enhanced the range to include the high performance and energy saving technology.
Product Description | iiyama ProLite P1905S-1 - LCD monitor - 19" | Device Type | LCD monitor - 19" | Features | Stereo speakers | Panel Type | TN | Aspect Ratio | 5:4 | Native Resolution | 1280 x 1024 | Pixel Pitch | 0.294 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Speakers | Integrated | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 41.5 cm x 20.1 cm x 42.1 cm | Weight | 5 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | TUV GS, DDC-2B, VESA DPMS, CB, TUV Ergo |
General | |
Display Type | LCD monitor / TFT active matrix |
Diagonal Size | 19" |
Built-in Devices | Stereo speakers |
Panel Type | TN |
Vertical Refresh Rate | 75 Hz |
Horizontal Refresh Rate | 81 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Controls & Adjustments | Mute, volume, brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Finnish, Japanese |
Features | HDCP, Protective Glass Panel |
Colour | Black |
Weight | 5 kg |
Audio | |
Type | Speakers - stereo - integrated |
Output Power / Channel | 1 Watt |
Connectivity | |
Interfaces | VGA , DVI-D , Audio line-in |
Mechanical | |
Tilt Angle | 20 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), wall mountable |
Cables Included | 1 x VGA cable , 1 x DVI cable , 1 x audio cable |
Power | |
Power Supply | Internal |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 20 Watt |
Power Consumption Stand by / Sleep | 1 Watt |
Software / System Requirements | |
OS Required | Apple MacOS, Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP, Microsoft Windows Vista |
Environmental Standards | |
ENERGY STAR Certified | Yes |
