Rapid refresh rate and frame rate guarantee smooth, blur free and judder free graphics, with lower latency and lag improving response times for fast paced games. Especially suited to the fast pace games like FPS, racers, MOBA and sports where the 144hz refresh rate delivers the crisp and sharp images needed to raise your game. For 144 fps game-play it is required to have a graphic card that supports dual link 144Hz DVI.
Product Description | iiyama G-MASTER Red Eagle GB2488HSU-B3 - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class B | Energy Consumption per Year | 52 kWh | Power Consumption (On mode) | 35.3 W | Adaptive-Sync Technology | AMD FreeSync | Features | USB 3.0 hub | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.277 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 / 12000000:1 (dynamic) | Response Time | 1 ms | Colour Support | 16.7 million colours | Input Connectors | 2xHDMI, DVI-D, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) | 56.8 cm x 23 cm x 38.8 cm | Weight | 5.6 kg | Compliant Standards | DDC-2B, DVI DMPM, PSE Mark, TUV Bauart, VCCI Class B, CU |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Built-in Devices | USB 3.0 hub |
Panel Type | TN |
Vertical Refresh Rate | 55 - 145 Hz |
Horizontal Refresh Rate | 30 - 160 kHz |
Horizontal Viewing Angle | +85 / -85 |
Vertical Viewing Angle | +80 / -80 |
Backlight Technology | LED backlight |
OSD Languages | Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Dutch, Japanese |
Features | HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), X-Res Technology, Flicker Free technology, blue light reduction, Black Tuner |
Colour | Black |
Weight | 5.6 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 3 Watt |
Connectivity | |
Interfaces | DVI-D , DisplayPort , 2 x HDMI , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , Audio line-in , Headphones |
Mechanical | |
Tilt Angle | -5/+22 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x DVI cable - DVI-D to DVI-D , 1 x DisplayPort cable , 1 x USB cable , 1 x audio cable |
Mounting Kit | Included |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 34 Watt |
