BT.com
Wishlist
iiyama B2282HD-B1 22" 1920x1080 5ms VGA DVI LED Monitor
Delivery
Standard Due date unavailable
The ProLite B2282HD is an excellent 22" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 5ms response time and 12 000 000:1 Advanced Contrast Ratio, assuring clear and vibrant picture quality and high contrast. The B2282HD is also Energy Star Certified. Height adjustable stand with PIVOT function makes this monitor an excellent choice for Universities, Corporate and Financial markets.
Iiyama ProLite B2282HD-B1 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Height, pivot (rotation), tilt
50.5 cm x 23 cm x 39.35 cm
4.7 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, DDC/CI, VCCI Class B
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, input select, colour temperature, phase
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
50.5 cm x 23 cm x 39.35 cm - with stand
4.7 kg
VGA (HD-15) , DVI-D (HDCP)
Mechanical
Tilt Angle
-5/+22
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x DVI cable - DVI-D to DVI-D
21 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Dimensions & Weight Details
Without stand - width: 50.5 cm - depth: 5.65 cm - height: 31.05 cm , With stand - width: 50.5 cm - depth: 23 cm - height: 39.35 cm - weight: 4.7 kg
ENERGY STAR Certified
5 °C
35 °C
10 - 80% (non-condensing)
Accessories
Accessories
£115.38
StarTech.com Articulating Monitor Arm
Quicklinx: BHCN | In Stock
£122.23
StarTech.com Dual Monitor Stand
Quicklinx: C19Z | In Stock
£79.03
StarTech.com Cubicle Monitor Hanger
Quicklinx: CFQK | In Stock
£54.34
StarTech.com TV/Monitor Arm - Wallmount
Quicklinx: CFR4 | In Stock
£78.40
Other bundles
£8.41
£9.42
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£10.56
£6.00
C2G USB to DVI Adapter Up To 2048 x 1152
Quicklinx: 8H1Y | In Stock
£44.74
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.92
£60.32
Scroll to top
