HyperX HX428C14SB2/8 is a 1G x 64-bit (8GB) DDR4-2800 CL14 SDRAM (Synchronous DRAM) 2Rx8, memory module, based on sixteen 512M x 8-bit FBGA components. Each module supports Intel® XMP (Extreme Memory Profiles). Each module has been tested to run at DDR4-2800 at a low latency timing of 14-16-16 at 1.35V. The SPDs are programmed to JEDEC standard latency DDR4-2133 timing of 15-15-15 at 1.2V. Each 288-pin DIMM uses gold contact fingers.
Product Description | HyperX Savage - DDR4 - module - 8 GB - DIMM 288-pin - 2800 MHz / PC4-22400 - unbuffered | Product Type | Memory module | Capacity | 8 GB | Memory Type | DDR4 SDRAM - DIMM 288-pin | Upgrade Type | Generic | Data Integrity Check | Non-ECC | Speed | 2800 MHz (PC4-22400) | Latency Timings | CL14 (14-16-16) | Features | Dual rank, black heatsink, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), Black PCB, low profile heatspreader, sixteen banks, asymmetrical heatspreader, unbuffered | Voltage | 1.35 V | Lead Plating | Gold | Manufacturer Warranty | Limited lifetime warranty (Russia - 10 years) |
General | |
Capacity | 8 GB |
Memory | |
Type | DRAM memory module |
Technology | DDR4 SDRAM |
Form Factor | DIMM 288-pin |
Module Height (inch) | 1.36 |
Module Configuration | 1024 x 64 |
Chips Organization | 512 x 8 |
Voltage | 1.35 V |
RAM Performance | SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP) - 2666 MHz - 1.35 V - CL14 - 14-15-15 , Intel Extreme Memory Profiles (XMP) - 2800 MHz - 1.35 V - CL14 - 14-16-16 |
Miscellaneous | |
Colour Category | Black |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty (Russia - 10 years) |
