HyperX Savage DDR4 memory is an unbeatable combination of fast speeds and aggressive timings to complement Intel's 2, 4, 6 or 8 core processors for faster video editing, 3D rendering, gaming and AI processing. With speeds up to 3000 MHz and latencies of CL12-CL15, it's optimized for Intel's Z170 and X99 chipsets and features easy overclocking with no need for manual timing adjustments in BIOS.
HyperX Savage DDR4 memory has lower power consumption than DDR3. Its asymmetrical, stylish, die-cast aluminum heat spreader has a low profile to fit under oversized CPU coolers and provide enhanced thermal dissipation to keep your system cooler as it complements the look of the PC hardware and helps you stand out from the "square" crowd. The heat spreader and matching PCB are made from quality aluminum material and feature a diamond-cut finish.
Attack the competition with style and confidence.
Product Description | HyperX Savage - DDR4 - kit - 16 GB: 2 x 8 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - unbuffered | Product Type | Memory kit | Capacity | 16 GB: 2 x 8 GB | Memory Type | DDR4 SDRAM - DIMM 288-pin | Upgrade Type | Generic | Data Integrity Check | Non-ECC | Speed | 2133 MHz (PC4-17000) | Latency Timings | CL13 (13-13-13) | Features | Dual rank, black heatsink, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), Black PCB, low profile heatspreader, sixteen banks, asymmetrical heatspreader, unbuffered | Voltage | 1.2 V | Lead Plating | Gold | Manufacturer Warranty | Limited lifetime warranty (Russia - 10 years) |
General | |
Memory | |
Type | DRAM memory kit |
Technology | DDR4 SDRAM |
Form Factor | DIMM 288-pin |
Module Height (inch) | 1.36 |
Module Configuration | 1024 x 64 |
Chips Organization | 512 x 8 |
Voltage | 1.2 V |
RAM Performance | SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP) - 2133 MHz - 1.2 V - CL13 - 13-13-13 |
Miscellaneous | |
Colour Category | Black |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty (Russia - 10 years) |
