Kingston's HyperX SSD combines the SandForce controller technology with premium NAND flash, reducing load times while increasing performance and endurance. It provides high-speed SATA Rev 3.0 transfer speeds for larger bandwidth, which power users require for advanced gaming, multitasking and multimedia computing power. Kingston's HyperX SSD lets users load games and applications faster, increase frames per second (FPS) and quickly transfer and edit large media files. It's cool, silent and requires less power and no additional cooling requirements.
When configuring the HyperX SSD partition, the user can choose between having the maximum available capacity for data storage or giving up a little space to increase performance and endurance. This additional space is called over provisioning on an SSD. The amount of performance and endurance increase depends upon the type of data being stored on the HyperX SSD. The more data that is MPEG, JPG, ZIP or ARC file types, the greater the benefit for this increased over provisioning.
HyperX SSD uses an advanced wear leveling technology that distributes writes evenly across all the flash blocks in the SSD to maximize overall drive endurance. Additionally, wear leveling ensures that the individual flash memory blocks are consumed at a very balanced rate, not to exceed a 2-percent difference between the most often written blocks and least written. This enables the HyperX SSD to provide the longest possible life for the user while maintaining optimal performance.
Product Description | HyperX Predator - SSD - 960 GB - PCIe 2.0 x4 | Type | Solid state drive - internal | Capacity | 960 GB | NAND Flash Memory Type | Multi-level cell (MLC) | Form Factor | M.2 2280 | Interface | PCIe 2.0 x4 | Features | Marvell 88SS9293 controller | Dimensions (WxDxH) | 22 mm x 80 mm x 3.5 mm | Weight | 10 g | Manufacturer Warranty | 3-year warranty | Bundled with | HHHL adapter |
General | |
Device Type | Solid state drive - internal |
Capacity | 960 GB |
Width | 22 mm |
Depth | 80 mm |
Height | 3.5 mm |
Weight | 10 g |
Performance | |
Drive Writes Per Day (DWPD) | 1.8 |
SSD Endurance | 1600 TB |
Internal Data Rate | 1350 MBps (read) / 1000 MBps (write) |
4KB Random Read | 111000 IOPS |
4KB Random Write | 72000 IOPS |
Maximum 4KB Random Write | 126000 IOPS |
Maximum 4KB Random Read | 160000 IOPS |
Reliability | |
MTBF | 1,000,000 hours |
Expansion & Connectivity | |
Interfaces | 1 x PCI Express 2.0 x4 - M.2 Card |
Compatible Bay | M.2 2280 |
Power | |
Power Consumption | 1.38 Watt (idle) , 1.99 Watt (read) , 8.25 Watt (write) , 1.4 Watt (average) |
Software & System Requirements | |
OS Required | Microsoft Windows Vista SP2, Microsoft Windows XP SP3, Microsoft Windows 7 SP1, Windows 8, Windows 8.1 |
Miscellaneous | |
Included Accessories | Low profile bracket, full height bracket, half-height half-length PCIe x4 adapter |
Compliant Standards | ISO 9001:2008, SGS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Vibration Tolerance (operating) | 2.17 g @ 7-800 Hz |
Vibration Tolerance (non-operating) | 20 g @ 10-2000 Hz |
