Conquer the workday with the perfect combination of brains and beauty. The iconic 39,6 cm (15.6") diagonal HP ZBook Studio is HP's thinnest, lightest, and most attractive full performance mobile workstation.
Brilliant inside and out
Make a bold statement with innovative style and performance. Starting at just 1.99 kg (4.4 lbs) and 18mm thin, the HP ZBook Studio is a meticulously-designed performance machine.
Create your ideal workstation
Get looks and performance with Intel® Xeon® processor options, dual 1 TB HP Z Turbo Drive G2 for up to 2 TB of total storage, up to 32 GB ECC memory, dual Thunderbolt™ 3, and optional HP DreamColor UHD or FHD touch displays.
Defined by HP Z DNA
Work confidently with HP mobile workstations designed around 30 years of HP Z DNA with extensive ISV certification. It’s reliable, designed to pass MIL-STD 810G testing, and endure 120K hours in HP's Total Test Process.
Product Description | HP ZBook Studio G3 Mobile Workstation - 15.6" - Intel Core i7 - 6820HQ - vPro - 16 GB RAM - 256 GB SSD - UK | Product Type | Mobile workstation | Operating System | Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English | Platform Technology | Intel vPro Platform | Processor | Intel Core i7 (6th Gen) - 6820HQ / 2.7 GHz, up to 3.6 GHz / 8 MB Cache | Memory | 16 GB DDR4 (2 x 8 GB) | Storage | 256 GB SSD - HP Turbo Drive | Display | 15.6" LED backlight touchscreen 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 530 | Input Device | Keyboard, ClickPad | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | Gigabit Ethernet | Battery | 4-cell - up to 9.5 hours | Security | Trusted Platform Module (TPM 1.2) Security Chip | Colour | Space Silver | Dimensions (WxDxH) | 37.5 cm x 25.5 cm x 1.8 cm | Weight | 2 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Operating System | Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English |
Processor / Chipset | |
CPU | Intel Core i7 (6th Gen) 6820HQ / 2.7 GHz |
Max Turbo Speed | 3.6 GHz |
Number of Cores | Quad-Core |
Cache | 8 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel CM236 Express |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 16 GB (2 x 8 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM - non-ECC |
Speed | 2133 MHz / PC4-17000 |
Rated Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 0 |
Storage | |
Main Storage | 256 GB SSD M.2 PCIe - HP Turbo Drive |
RAID Level | RAID 0, RAID 1 |
Display | |
Type | 15.6" - IPS |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | Multi-Stream transport (MST), Full HD ultra wide-viewing angle (UWVA) eDP anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 530 |
Camera | Yes - 720p |
Video Resolutions | 1280 x 720 |
Frame Rate | 30 frames per second |
Camera Features | 720p HD movie recording, low light enhancement |
Sound | Stereo speakers, two microphones |
Codec | CX7501 |
Compliant Standards | High Definition Audio |
Audio Features | Output: Bang & Olufsen Audio |
Input | |
Type | Keyboard, ClickPad |
Keyboard Layout | UK |
Features | Volume control, spill-resistant, ClickPad with gesture support |
Communications | |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 4-cell |
Capacity | 64 Wh |
Run Time | Up to 9.5 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 150 Watt, 19.5 V |
Connections & Expansion | |
Interfaces Details | LAN , 3 x USB 3.0 , 2 x Thunderbolt 3 , Headphone/microphone combo jack , HDMI |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC UHS-II Card) |
Software | |
Software Included | HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, HP Performance Advisor, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Intel Wireless Display, Password Manager, Windows Defender, HP Client Security, HP Mobile Connect, HP Systems Software Manager (free download), HP Velocity, HP Secure Erase, HP Security Manager, HP BIOSphere, HP GPS and Location, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Credential Manager, HP Client Catalogue (free download), Absolute Persistence, LANDesk Management Suite (free download), HP CIK for Microsoft SCCM (free download), HP Noise Reduction Software, HP Image Assistant |
Miscellaneous | |
Case Material | Magnesium-aluminum alloy |
Features | Power-on password, HP 3D DriveGuard, Intel Active Management Technology (iAMT), HP DuraKeys, HP SpareKey, One-Step Logon, HP BIOS Protection, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port, Pre-boot Authentication, HP Sure Start with Dynamic Protection |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 2 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
